Tyre Pressures
Just starting again after a 12yr break, can't remember the correct tyre pressures for competition use, all replies welcome ;)
For adult rider on Michelin's would suggest
4 psi rear, front 5.5psi
Get good quality low pressure gauge.
If weather warms up check a few times as can easily rise 1/2 psi
Thanks Jimmy, I'll try them out, I got myself a nice new Apico 0-15psi gauge that should do the trick ;)
check each tyre 3 or 4 times in succession to get a steady reading. Don't just go on first reading
I have IRC tyres and run the back at between 2 1/2 - 3 psi if there is no rocks and go up to 3 1/2 if there is lots of rocks. I run the front at 4 1/2 in all conditions unless is really muddy and then drop to 4.
The bike I am getting has those new Michelin Light tyres on it, anybody got experience of pressures for them?? ;)
Have been informed that the first batch of Raga Reps do not have the Michelin Lights fitted.
You are joking!!, dam I hope everything else is to spec or its an expensive gold paint job ;)
