Piston
44wilky44
Theres a local motobike shop nearby which is spose to reline/polish the head for 10 pound , then fit an over sized piston dose this sound true if so is it just as good as a reline.
remove head very mild dark lines
thanks lee
What bikes it on? If its an older one you could get away with it i guess but if its a newer Nikosil coated then no, won't work.
To put it in perspective a rebore and piston will cost you in the region of
