September 13, 200917 yr Chaps, Been playing around with this 125 for a couple of weeks now and at my wits end!! Looking for some advice on carb set-up.... It's a Keihin - 52 pilot, 127 main, needle on middle position.... I've been told that this is the standard setting for an Evo.......but, I just don't seem to be able to get the thing to pull off the bottom in 2nd without it choking up/stalling.... Starting to wonder whether 2nd is only good for full throttle sections/climbs etc... Anybody out there have any thoughts on jetting/needle alternatives?? Or how to ride a 125!!! Cheers! Scott
September 13, 200917 yr hi scott, my son rides a 125 evo, and to be honest it runs spot on on the standard jetting with castrol tts oil mixed at 70:1. he probably rides 90% of sections in 1st gear only using 2 and third on bigger climbs and mud. i take it that you are an adult rather than a schoolboy rider? if i ever ride my sons bike i find that it seems to bog in 2nd gear ,then again i am about 5 stone heavier than him. perhaps you just need to rev it harder as its only a 125 and they dont exactly have that much flywheel weight for being grunted through sections in 2nd gear.
September 13, 200917 yr Differnt bike i know, but my rev3 125 (07) will pull 2nd 3rd off the bottom no problem. Just like my old montesa 315! I have a 105 main and a 45 pilot.
September 13, 200917 yr Author ...thanks for the comments guys... Spudsdad - any idea on what jetting/needle position you have on your set-up? Did you have any joy with those V-force reeds btw? yamahaty250xox - I'm guessing that you're running a mikuni? I am wondering about dropping the pilot jet a tad.....see if I can lean it out a bit off the bottom. When you give it a handful in 1, 2 or 3rd it pulls really well.....find it's only on 1/8 - 1/2 throttle that it struggles.... Cheers chaps...
