Montesa Cota 349
andyz
Hi All,
I've just purchased a 1979 Cota 349 as a first foray into the world of classic trials, after years of motocross and enduros.
The bike had been laid up for a few years and the owner claimed that it had been completely rebuilt (whatever that means) previous to this. After putting new oils in the primary and gearbox and fresh fuel in the tank, it fired up, second kick, but it seems very rattly! So rattly in fact that its a bit emabarassing riding it in my back garden!
The noise seems to be mostly from the top end, possibly piston slap and small end, but its hard to tell. Should this engine be mechanically quiet, or is a bit of rattle normal? If its not normal then could anyone suggest the most common source of rattling on this type of engine.
The other area of concern is the lack of any protection of the swinging arm from the top run of the chain. I believe that the rubber tubes which were fitted to these bikes originally are not easy to find, so how does everyone else stop the chain wearing through the swinging arm?
With those minor items sorted, I'll then be looking for any classic trials going on in Kent, UK and surrounding areas - suggestions very welcome!
Many thanks,
Andrew
Yes probably piston slap but may also be the primary drive gears if the crank end is running out. If the noise is from the primary gears the noise will be the same under most conditions while piston slap will sound worst while on closed throttle overrun from highish RPM.
Spring loaded tensioners seem to be more popular than the chain guides. Theres a neat one available that mounts on the gearbox case. Have a look at what other riders use. Museum standard bikes will have the tube guides while many ride bikes have a tensioner.
Hi All,
I recently bought a 349 chain tensioner from Sandifords through Ebay. It came complete with the swinging arm protector. It was dirt cheap aswell!
Give them a call - if they've run out send me an email and I'll give you mine. It doesn't fit my Cota 330.
Steve
Interestingly my 349 was completely rattle free before I stripped it down to find the whole engine badly corroded! To be fair the piston looks unworn, but the point to make is that a 349 in "normal" condition should not really rattle should it?
Unfortunately taking the barrel off is not as easy as some bikes due to recessed bolts... but there is a post of my experiences (and advice) if you decide to open her up.
Steve
