Rather Loud 2001 Rev3
braddon
I went to my first trial yesterday and several people commented on how loud my bike was.
I didn't notice it until then but now it is rather loud compared to all the other trials bikes there.
I Was told it would be a good idea to pack the exhaust tighter, i did this a few months ago but still took it all out and did it tighter.
I managed to fit a lot more packing in doing it as compact as i could.
Its still just as loud after doing this though.
Any suggestions on what i could to to quieten it?
Thanks
Never done a Beta but most bikes have a baffle tube (perforated) if this is clogged up with carbon & oil gunge which is possible it wont allow the sound to be absorbed and thus dissipated. The bike will ride better too if you get it right.
Yes. Take out the packing and either put some of it or some new stuff in quite loosely after making sure the tube is clean as Chewy says. You want the packing to fill the available space around the perforated tube but definitely not to be wedged in tightly otherwise it won't absorb the sound as you have found. Should soften up the power a bit.
Yeah the tube is clean i cleaned it out with a wire brush and blow torch when i repacked it to get all the carbon off.
So i need to pack it again but not tightly just to fill the space?
This could be where i am going wrong as it is as tight as i can get it at the moment.
I was told you can use fibreglass roof insulation for it as i have run out of the proper stuff, is this correct and will it affect performance etc at all?
Thanks
Yep loft insulation is OK - that's what I've got in mine at the moment. I used some of the slab stuff like they put between the walls of new houses, but you could use any of the roll types I should think. You need to fill the exhaust with loosely packed insulation. If you find yourself ramming it in with a piece of wood it's too tight. I did mine twice before I was satisfied with the result. The other option, of course, is to get a replacement packing from Lampkins that should be just right.
Are there any O-rings or other seals on the Rev exhaust where it could be leaking? Do you have to seal the end on with silicone when you've repacked it? Maybe you can feel with your hand if it's leaking anywhere where it shouldn't be. If it's leaking it won't help, of course. If you can't find anything wrong I'd experiment with different amounts of packing, including none to get a feel for how much you're quietening it, and then once you've found the best amount seal it up with some silicone sealant. Maybe give Lampkins a ring to see what they say?
  • 2 years later...
Hi, you have the same problem as me and it does not seem to be easy to fix!
I have two 2008 270 Beta Rev 3's, one has clearly been abused and is very loud, the other is 'as new' (still on original tyres) and this one sounds lovely. I swapped the mid sections around and the 'dog' sounded lovely too...
The two centre boxes are totally different weights so I can only draw conclusions that it is really chocked up... and here lies my/your challenge.
I tried burning it out yesterday with petrol (do a search) but it seems no better.
I am a bit lost what to do... Hopefully an exhaust guru will come along and help out... who knows maybe someone will even offer a mid section repair service...
See ya
Brief update!
Had another go this morning and a better result (but not perfect).
I got the exhaust much hotter by filling with petrol, draining and then burning it out three times. The temp went well over 100 degrees centigrade so I has plenty of water on hand to cool the metal work whilst blasting air in from my compressor.
I could see the 'burn' had worked in much of the box (but not all) because the inner baffle was burned clean (ie no carbon deposits, dirt or otherwise)
You can tell if the gunk is burning by a dark grey white smoke that doesn't smell like petrol.. (the petrol burning off will just be a black sooty smoke)
Could probably do better but maybe next year.
Definately better but as above not perfect.
See ya
