S3 Pipe On 125 Pro
I'm thinking of buying an S3 exhaust for my 08 125 Pro....anyone got any experiences..good or bad?
Thanks!
Andy
It Certainly increases the Power!! There is also an Insert that increases Bottom end on the 125. It fixes into the head outlet and the pipe inlet.
Thanks for the info...are you talking from personal experience here? Did you have to make any carb/jet changes or is it a starightforward 'bolt-on'?
Cheers
Andy
I put an s3 pipe, with the insert, onto my 08 sherco 125. I made a huge difference to bottom end power. Presumably it would do the same to the gas gas. On sections with tight turns then a climb i can now use a higher gear without the same fear of stalling, or having to change gear mid section.
from experience the pipe really doesnt make that much difference the insert makes more of a difference if you wanna spend some cash buy a keihn carb definatley worth the money
