gronno Posted November 28, 2009 Share Posted November 28, 2009 Just wondering if there is a known problem with Pro G/boxes jumping into gear? Mines jumped in a couple of times now, just after starting, is it a symptom of something about to let go or 'they all do that sir'? Running recommended dextron III ATF oil. Ta muchly. Quote Link to comment Share on other sites More sharing options...
laser1 Posted November 29, 2009 Share Posted November 29, 2009 Does the bike also shift hard in some gears as well. For instance, it hard to get into second - or maybe it upshifts into 2nd OK, but hard to down shift form 3rd?? If so, it's possible you just need to adjust the eccentric preload adjuster on the shift shaft. If you watch the engine repair video on the trials parts USA site, it will show you how to do it. There was a recent shifting thread that had the exact info on the video. Quote Link to comment Share on other sites More sharing options...
jandyb Posted November 29, 2009 Share Posted November 29, 2009 Does the bike also shift hard in some gears as well. For instance, it hard to get into second - or maybe it upshifts into 2nd OK, but hard to down shift form 3rd?? If so, it's possible you just need to adjust the eccentric preload adjuster on the shift shaft. If you watch the engine repair video on the trials parts USA site, it will show you how to do it. There was a recent shifting thread that had the exact info on the video. http://www.trialscentral.com/forums/index....showtopic=27909 -JAn Quote Link to comment Share on other sites More sharing options...
gronno Posted November 29, 2009 Author Share Posted November 29, 2009 I can't say I've noticed any other symptoms thankfully. I'll have a gander at the video though. Quote Link to comment Share on other sites More sharing options...
gronno Posted November 29, 2009 Author Share Posted November 29, 2009 Great vid, I didn't know that about the sharper edge on a circlip, makes complete sense. I'll check for the gear lever click thing, good stuff. Quote Link to comment Share on other sites More sharing options...
