bigmike1961 Posted November 28, 2009 Share Posted November 28, 2009 (edited) Are the front brake master cylinders generic or bike specific for the SY250. Reason for asking is I've just sheared off the cap head screw that clamps the whole shooting match to the handle bar and the other one won't shift either. I was trialing tomorrow too. Briefly (very briefly) contemplated riding as it was - brake held on by 1 cap head screw and spinning about all over the place. In stead got the trusty drill out to drill out the screw and yep,you guessed it, the drill wandered off into the softer alloy!!! Blast, drilled and tapped the result to M5 and put a bolt in which holds everything as it should be but it's not right. Are there any up grades, what do you recommend? Where is best to purchase one? Edited November 28, 2009 by BigMike1961 Quote Link to comment Share on other sites More sharing options...
motofire Posted November 29, 2009 Share Posted November 29, 2009 Not positive but you may be able to go to a Yamaha dealer a get a M/C for a YZ and bolt it right on. Might be the same as the SY. Quote Link to comment Share on other sites More sharing options...
tt5th Posted November 29, 2009 Share Posted November 29, 2009 Master cylinders are generic, you just need the right brake line. If the one you have won't fit any good bike garage should be able to make you one up with the right fittings. The Nissin cylinders from Honda motocross bikes are good. Quote Link to comment Share on other sites More sharing options...
tony27 Posted November 29, 2009 Share Posted November 29, 2009 Should be the same as most other trials bikes that run AJP master cylinders, sherco are the only make from memory who use a different way of routing the hose. Most have the end of the hose threading into the cylinder but sherco uses a banjo fitting at the back. See whats available at short notice & fit it, you probably won't notice any difference Quote Link to comment Share on other sites More sharing options...
bigmike1961 Posted November 29, 2009 Author Share Posted November 29, 2009 Thanks for the replies, anyone out there know what the AJP part number might be? Quote Link to comment Share on other sites More sharing options...
paulmac Posted November 29, 2009 Share Posted November 29, 2009 this is the Scorpa Part Number S1A-40501-00-00 - not sure whre you are but Hell Team in OZ or Birketts in the UK should have them. Paul Mac Quote Link to comment Share on other sites More sharing options...
bigmike1961 Posted November 30, 2009 Author Share Posted November 30, 2009 Thanks for that, I think I've found a replacement. I was going to try for a repair but I think a new one might be better after my bad drilling out of the sheared screw. Quote Link to comment Share on other sites More sharing options...
