littleblackflash Posted December 6, 2009 Share Posted December 6, 2009 Hi All. I have a 1972 Bultaco which has a fully rebuild engine with electronic ignition. But I can't get it to start as it should. If I use Easystart (or brake cleaner) it will fire up and run well. I can turn it off and it will restart 2-3hrs later first kick. But if I leave it overnight, it won't start. I'm using a new BP5ES plug with a 0.7mm gap as per the ignition instructions. What should I try now? Quote Link to comment Share on other sites More sharing options...
davieboy Posted December 6, 2009 Share Posted December 6, 2009 What carb are you using? Sounds like the usual Amal mk2 choke circuit is blocked.Try cleaning it out with an airline. My own Model 190 usually starts after 2 or 3 kicks from cold but always with the choke on and a closed throttle,if you twist it when kicking it refuses to start. If it is a Mk1 does it start with copious amounts of flooding?I had a Model 92 with an Amal mk1 and it had to be flooded then kicked then flooded again then kicked a few times before it would start from cold. Both bike would start from hot very easily. I also use points ignition,set up meticulously and cleaned regularly with no problems. Quote Link to comment Share on other sites More sharing options...
littleblackflash Posted December 6, 2009 Author Share Posted December 6, 2009 I'm using a Mk1.5 Amal Carb. 627 from memory. It is a cold start problem. I've cleaned all the carb out but I'll have another go. The choke is a primative button that pushes down on the float to flood the engine. When I push the choke plunger down, some fuel leaks out around the plunger. Is that normal? Quote Link to comment Share on other sites More sharing options...
davieboy Posted December 6, 2009 Share Posted December 6, 2009 I'm using a Mk1.5 Amal Carb. 627 from memory. It is a cold start problem. I've cleaned all the carb out but I'll have another go. The choke is a primative button that pushes down on the float to flood the engine. When I push the choke plunger down, some fuel leaks out around the plunger. Is that normal? Yes,it is called a tickler button. Try pushing this button up and down until fuel flows out,kick the engine over a couple of times then repeat the flooding and kicking until the engine starts. Quote Link to comment Share on other sites More sharing options...
littleblackflash Posted December 6, 2009 Author Share Posted December 6, 2009 I'll give it a go tomorrow. Cheers Quote Link to comment Share on other sites More sharing options...
harvey_mushman Posted December 6, 2009 Share Posted December 6, 2009 Are you shutting the fuel off between starts? I have a Yamaha DT250 Enduro that will fill the crackcase with fuel if I forget to shut it off after running. Float valve needle and seal are new, bike runs great, yet it still finds a way to flood out. Quote Link to comment Share on other sites More sharing options...
woody Posted December 6, 2009 Share Posted December 6, 2009 You carb will be an Amal MK1 if it has the tickler, the MK1.5 was a MK1 body but with different pilot circuit and with a choke lever fitted, no tickler. If it is a 627 then the chances are it is the original carb so you could also have wear in the throttle slide/throttle body which may hinder starting from cold as it will weaken the mixture a bit. When you press the tickler down until fuel pours out, this has flooded the carb and the biike should start first or second kick if the carburation is ok, even with a worn slide generally. (this is assuming the electronic ignition is performing correctly and the timing is correct) Quote Link to comment Share on other sites More sharing options...
kttwofifty Posted December 13, 2009 Share Posted December 13, 2009 One word for you guys........................MIKUNI Quote Link to comment Share on other sites More sharing options...
littleblackflash Posted December 20, 2009 Author Share Posted December 20, 2009 The bike has been starting first time, every time if I press the tickler once and DON'T turn the fuel off each time. If I do turn the fuel off, the bike won't start after being left over night. No sign of a fuel leak and in both cases, the bike had not been moved. Quote Link to comment Share on other sites More sharing options...
