Cota 200 Fork Seals
ikb
I'm just about to order some new fork seals and was wondering why there are 2 in each leg? Is it because 80s seals werent up to it? If so I would fit only 1 to reduce friction???? (with suitable spacer).
Ian
Whether or not this is correct is open for discussion, but I've always believed that when installing two seals in one leg, the first (bottom) seal is installed with the open or spring side of the seal facing down to wipe off oil. The second (top) seal is installed upside down (spring side up) to wipe off dust / dirt and protect the bottom seal.
