dan williams Posted August 24, 2024 Author Share Posted August 24, 2024 Not sure what difference this may make but just adding to the general knowledge I notice the Beta fiber plates are now noted as being Ferodo rather than Adige. I personally haven't seen any but I do see Beta wants a lot more money per plate. Quote Link to comment Share on other sites More sharing options...
dan williams Posted August 29, 2024 Author Share Posted August 29, 2024 I noticed some of the bikes that use the 3mm Barnet plates also call out 1 plate with a different number. I ordered one just to see if it’s the same form factor with a different thickness. I’ll let you all know what I find. Quote Link to comment Share on other sites More sharing options...
dan williams Posted August 31, 2024 Author Share Posted August 31, 2024 Interesting the plate is still 3mm thick but the friction material is semi-metallic and the plate width is thinner. Something I didn’t notice about the kevlar plates is they are slightly wider than the stock plates.🤔 Quote Link to comment Share on other sites More sharing options...
