drillman Posted February 7, 2010 Share Posted February 7, 2010 Having a blank moment How do you remove the front wheel on a 2008 txt Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted February 8, 2010 Share Posted February 8, 2010 Undo the two pinch bolts on the bottom of the left hand fork, or right, cant remember, but it'll be obvious. Then an allen key in the spindle, and turn till it comes out of the threaded fork leg, then just pull/wriggle. Quote Link to comment Share on other sites More sharing options...
husky Posted February 8, 2010 Share Posted February 8, 2010 Undo and remove allen key headed nut[10mm I think] on brake side of forks,undo spindle pinchbolts on both forklegs,the spindle pushes out to the right.You don't need a b*******great allen key on the right side Quote Link to comment Share on other sites More sharing options...
smalley250 Posted February 8, 2010 Share Posted February 8, 2010 Pinch bolts on both right and left frok leg then the allen key bolt on the brake disc side then the spindle should pull out, that said ive had to remove brake callipier which made it less tension on spindle. Quote Link to comment Share on other sites More sharing options...
