May 15, 201016 yr I have been doing some jobs on a friends 199a and have taken the Bing carb off to clean it out.Blew it out with an airline and put it back on the bike.Now the bike runs very poorly as if it is getting too much fuel and flooding,though there is no petrol coming out anywhere.The bike runs as if the choke is on and when you put the choke on it is worse.I have messed about with the float height but seems to make no difference.I know the bike runs fine otherwise as I have put the Amal carb from my own 190 onto it and it runs fine with it on.I have had the Bing on and off numerous times,checked the choke is not stuck on,blown jets out etc but to no avail. The bike was running ok before I cleaned out the carb so it is something I have done,I cannot see anything missing,it is pretty basic anyway. Anyone any ideas?
May 15, 201016 yr Author Hi DavieNeedle valve not seating / damaged ? Ross Hi Ross,I think this must be the problem.Tried blowing through with a bit of tube then shutting off with the floats.Seems to take a bit of pressure before the valve shuts off. The floats must not be shutting the fuel off.I don't have another needle valve to try,I have amals on my other bikes. You coming tomorrow?
May 15, 201016 yr Author Yes,see you there, new venue for me, any good ? I've only ridden motocross track,haven't seen where the sections will be so new to me too.
May 17, 201016 yr I had the same problem with a Bing- check that the float actually floats. Mine was taking on gas making it too heavy.
