high_fiver Posted June 15, 2010 Share Posted June 15, 2010 (edited) Bike sounding a bit rough and spluttery when idling fine when i open the throttle any ideas of what could be causing it ?? also seems to be running a bit hotter than normal (or maybe it's just the hot weather makes it feel like that) all fluid levels fine using 80:1 mix and never been a problem before thanks in advance Ali Edited June 15, 2010 by High_Fiver Quote Link to comment Share on other sites More sharing options...
lowbrow Posted June 15, 2010 Share Posted June 15, 2010 Cleaned the carb lately? Sounds like its due for one. Quote Link to comment Share on other sites More sharing options...
high_fiver Posted June 15, 2010 Author Share Posted June 15, 2010 i'll give it a clean out only done last month though but worth a try Quote Link to comment Share on other sites More sharing options...
chr155_d Posted June 15, 2010 Share Posted June 15, 2010 Strip n clean carb, put in a new spark plug, clean and replace air filter! Drain replace radiator with fresh coolant! Start up using fresh premixed fuel! That should ensure it runs smoothly! Quote Link to comment Share on other sites More sharing options...
jse Posted June 15, 2010 Share Posted June 15, 2010 Bike sounding a bit rough and spluttery when idling fine when i open the throttleany ideas of what could be causing it ?? also seems to be running a bit hotter than normal (or maybe it's just the hot weather makes it feel like that) all fluid levels fine using 80:1 mix and never been a problem before thanks in advance Ali After adjusting the mixture screw, if it's still rough I'd look into: water in fuel or stale fuel. We often store the bikes with a partial full fuel tank which presents two problems, a larger surface area of fuel to allow "boiling off" or evaporation of the high-end aromatics that aid starting and low-speed running and, a volume of air that presents condensation of water. This can be cumulative and the results build on themselves to eventually cause symptoms. I like to store my bike in between rides with a full tank. Possible air leak. Usually this involves the manifold/reedcage area and most often is caused by over tightening the manifold (the capscrews only go to about 7-8 ft lbs max) which causes the manifold to bow in between the bolt holes. a still obstructed pilot jet. At .35/.38mm, the pilot jet is extremely small and a piece of grit can easily lodge in it. Most of us use fuel cans for years and dirt can accumulate in the bottom of the container so it's a good idea to add an inline fuel filter. When using compressed air to clean jets or passageways in carbs, always force the air in the opposite direction that the air of fuel flows as the orifices are usually funnel-shaped and this will prevent the particle from staying lodged at the bottom of the "funnel". Jon Quote Link to comment Share on other sites More sharing options...
chr155_d Posted June 15, 2010 Share Posted June 15, 2010 Strip n clean carb, put in a new spark plug, clean and replace air filter! Drain replace radiator with fresh coolant! Start up using fresh premixed fuel! That should ensure it runs smoothly! one more thing, check your fan is coming on? Maybe your thermostat! Quote Link to comment Share on other sites More sharing options...
