Need An '07 Rev 3 Left Case Cover
phineas7
I see on here that it's common problem. Mine did not leak into the gear box. It corroded at the impeller cover and started dripping on the floor.
I've tried calling the number for US Beta, but all I ever get is a recording.
Anybody know where I can get the aluminim replacement in the USA?
What other parts should I go ahead and get?
Is there a pump shaft seal?
I assume gaskets, but what about the impeller cover itself? Will it be next?
Thanks!
P7
You will need a few parts, case, water pump seal, case gasket, shift shaft seal, kick starter seal the new case doesn't have these seals and if you bend one taking it out you'll wish you would have ordered them, You will have to look at your pump cover to make the call on if you need a new on.
