Tlr200 Electrics Removal And Spokes
keychange
Hi I'm new to the forum and to TLRs
I have acquired an 1982 TLR 200 that requires quite a bit of tidying up and replacement parts
One thing I want to do away with is all the lighting and the battery. No problem removing all of it but I am concerned about what connections I have to jump in order to make it run without battery and not damage the CDI
I am also on lookout for front and rear spokes. The gold rims are fine but spokes are very badly rusted.
Cheers
Andrew
Dorrigo - Australia
just trace the wires for the lights ect back, and if you just disconect them it will be ok, the cdi does not require a battery to run, so about 1/2 hour should see it done.
it is quite easy to do, unless someone has mucked about with it
