mjc477 Posted September 3, 2010 Report Share Posted September 3, 2010 (edited) hi i have a 1976 tl125 with 150 kit on it it did run like a watch only a fortnight ago i went to start it the other night and it has completely lost its spark at the points it is in of road trim so only has a generator,coil, points and coil i disconnected the kill switch no spark changed plug plus plug cap no spark got my multi meter out on all cables all had continuity is this a common problem and does anyone know the next sensible place check there is next to no wiring on this bike so it surely must be a component failure cheers guys jason Edited September 3, 2010 by mjc477 Quote Link to comment Share on other sites More sharing options...
tltel Posted September 3, 2010 Report Share Posted September 3, 2010 Hi Jason I have the same bike and in the past have had similar problems. I cant remember if there is an earth for the coil but if there is, check and clean this first. It is more than likely to be the points that are causing the problem, I ve never had a problem with generators or coils. Check that the points are clean and definately closing and opening, turn over by hand. Check for a frayed wire on points conection a single strand of wire touching the engine will stop it sparking.( I have had this happen and its not obvious at first glance) If that is all ok could be condenser but you will usually get a lot of arcing at the points. Finally check for up and down movement on the cam shaft, if its got movement it will alter ponts gap when it is spinnig. Hope this helps. TLTEL 1 Quote Link to comment Share on other sites More sharing options...
mjc477 Posted September 3, 2010 Author Report Share Posted September 3, 2010 cheers for that i will check points tomorrow for bad connection and damaged wire i dont think its the condensor as i have had problems with them on an old vw camper and it was eating points weekly the points are like new if not indeed new ones fitted thanks Quote Link to comment Share on other sites More sharing options...
tlrider Posted September 3, 2010 Report Share Posted September 3, 2010 Check the condensor wire at the coil. Mine broke there once and I had no spark. Quote Link to comment Share on other sites More sharing options...
mjc477 Posted September 4, 2010 Author Report Share Posted September 4, 2010 Check the condensor wire at the coil. Mine broke there once and I had no spark. hi this morning i checked the points and found a very poor connection on the points lead crimp so i solderd it up i had a great spark!!!!!! i put a few things back on i had of and it ran for about 20 seconds very iraticaly then pop and it stopped obviously the last spark on some unspent fuel now i have no spark again i think now i will change the points and possibly the coil and condensor Quote Link to comment Share on other sites More sharing options...
tltel Posted September 4, 2010 Report Share Posted September 4, 2010 Hi Jason Still sounds like the points area is where you will find the priblem. The wire that runs into the points through the rubber grommet could be at fault, if its an original wire, change it as they become brittle. When you screw the points cover on it could be shorting out. Try startimg it without the cover on and see if its any different. good luck TLTEL 1 Quote Link to comment Share on other sites More sharing options...
mjc477 Posted September 5, 2010 Author Report Share Posted September 5, 2010 Hi JasonStill sounds like the points area is where you will find the priblem. The wire that runs into the points through the rubber grommet could be at fault, if its an original wire, change it as they become brittle. When you screw the points cover on it could be shorting out. Try startimg it without the cover on and see if its any different. good luck TLTEL hi i have had the cover off and have checked cable with multi meter and it is fine i did rewire the cable anyway but still no difference i have rewired all other cables now generator-points points- coil still no spark i will get new points anyway now i have also buzzed out the circuits and i have a dead short to ground on the generator windings this does not seem right to me???? thanks again Quote Link to comment Share on other sites More sharing options...
mjc477 Posted September 5, 2010 Author Report Share Posted September 5, 2010 Hi JasonStill sounds like the points area is where you will find the priblem. The wire that runs into the points through the rubber grommet could be at fault, if its an original wire, change it as they become brittle. When you screw the points cover on it could be shorting out. Try startimg it without the cover on and see if its any different. good luck TLTEL hi tltel thanks for all your imput i have just come back from the garage smelling of exhust fumes as its now running.... what i found was the wire connecting onto the points was connected on the wrong side the correct order is The order from left to right should be - bolt, upper ignition point metal band (upper point contact is on this band), b/w wire attachment, insulator, contact point housing (the actual metal piece that attaches it to the backing plate), insulator, washer, lock washer and nut. mine was connected on the wrong side of the mounting plate it still did have a circuit all be it thru a load of connections i connected the crimp straight onto the metal band of the top point and their it was a nice thick spark....... it had run like that for ages and now it had given up cheers again for your time jason 1 Quote Link to comment Share on other sites More sharing options...
stpauls Posted May 30, 2025 Report Share Posted May 30, 2025 On 9/4/2010 at 6:57 PM, tltel said: Hi Jason Still sounds like the points area is where you will find the priblem. The wire that runs into the points through the rubber grommet could be at fault, if its an original wire, change it as they become brittle. When you screw the points cover on it could be shorting out. Try startimg it without the cover on and see if its any different. good luck TLTEL "Shorting out on points cover". I sent my bike to two garages. Neither could sort it out. Finally I was looking at the engine when I noticed a little black mark on the inside of the points cover. It was arcing across to the cover and shorting out, 1 Quote Link to comment Share on other sites More sharing options...
