February 18, 201313 yr How about http://www.graupner.de/en/products/a1dcd87d-945f-4945-8731-eacf47cadb4a/productcategory.aspx
February 18, 201313 yr How about http://www.graupner....ctcategory.aspx i have looked all over that website. i will ring the graupner company tomorow. thanks for looking anyway.
February 22, 201313 yr http://www.modelshopleeds.co.uk/catalog/product_info.php?cPath=26_27_309&products_id=5219
January 14, 201412 yr For the squeel ; Try adding to your servicing a "tiny" drop of oil applied to the shaft end (the end under the ribber cover) "1" drop every 6 mth is enough. Will probably give you a much longer fan motor life. The squeel is just the bearing being a little dry. For my part never wash the bike with a power hose as its death to the suspention articulation as well. If you must be posh a bucket and sponge is much better ) Regards
June 27, 201412 yr I've looking for a motor for a while because mine was squealing without any joy, but stumbled across this one from Leeds. Rang the guy and he told me they are a direct replacement for the graupner one. £13.45 inc postage, Happy days. http://www.modelshopleeds.co.uk/catalog/product_info.php?cPath=38_144_297&products_id=5207
July 7, 201412 yr Hi Trialers, do we have a cheap fix for this fan? It is outof a Pro250 year 2002. It looks like this electromotor is complete package, right? Old question but the answer to it is that the older motors are common to Japanese roadbikes, a few years ago I bought the fan unit from a Honda VT250 which has the same numbers on it & the included fan blades were even the same, the plug had an earth wire but I changed the plugs over to suit
October 1, 201411 yr Here's a money saving tip if you're a plonker like me; If you hear noise from the fan intermittently then check to see that any cables, tubes or wires are interfering. I noticed the fan made noise after big drop offs and finally figured out that one of the radiator overflow tubes was rubbing on the fan. Silly me.
October 21, 201411 yr Old question but the answer to it is that the older motors are common to Japanese roadbikes, a few years ago I bought the fan unit from a Honda VT250 which has the same numbers on it & the included fan blades were even the same, the plug had an earth wire but I changed the plugs over to suit Hi thanks for this info. Mine is a year 2000 TXT 280 (before the pro model) and I searched ebay for honda 250 fans from older bikes and found one for a fiver. The only difference was the 3 mounting holes, I had to used a grinder to cut away at the mounts as they werent as the above photo with the end gaps. But fitted now and works spot on!
October 21, 201411 yr Here's a money saving tip if you're a plonker like me; If you hear noise from the fan intermittently then check to see that any cables, tubes or wires are interfering. I noticed the fan made noise after big drop offs and finally figured out that one of the radiator overflow tubes was rubbing on the fan. Silly me. THere isn't much room in there so very easy to catch a wire or plug on the fan when fitting the tank! I also had this issue.
December 5, 201411 yr I found a way to remove the motor without destroying it. You drill a couple of holes in the fan to access the two motor mount screws. Then when you tap out the shaft, the motor will fall out. You can now lube both bearings if squealing and replace the motor. Put some tape on to cover the drilled holes when finished. You could also try pulling the fan. The fit isn't as tight as before on mine and I can pull off and push on the fan without much effort. I ordered a motor from a US source and it looks like it will fit. Geeks use these motors to build robots. http://www.trossenrobotics.com/store/p/5151-RS-540-Motor-12V.aspx
December 17, 201411 yr What year bike are you on sectionone? Mines started squealing quite abit now so need to do something about it dont fancy paying out big bucks for a proper one.
December 22, 201411 yr Mine is an 07. When mine started squealing a several years ago I kept lubing it and it lasted another year before burning out. If you drill the fan like my tip, you could probably get more life by lubing both ends of motor. Here's a cheap motor that might work but the shaft isn't round. You could put epoxy in it. http://www.amazon.com/dp/B0096BJ92E/ref=pe_385040_128020140_TE_3p_dp_1 I burned out a Graupner Speed 500E motor after a few years which is actually a Mabuchi motor with a sticker on it. Right now I'm using a motor pulled from a O2 Cool 10 inch portable fan.
February 9, 201511 yr Done mine last week, ordered motor from model shop leeds. Great job, a little patience is all that is needed. I used a two part split bearing puller to support the motor housing when knocking out the fan blades. Take your time and think about it and dont be scared to hit the motor shaft with a small punch to release it from the fan blades.
April 8, 201511 yr Mine died today, unfortunatly couldnt get the blades of without damaging. Friend of mine probably has some old ones left so will try again. After destroying it, it did all fit, so t should be possible Also had some fun with the radiator mounting bolds Will need to weld the bar between those mounting points so bit more work to do! Edited April 8, 201511 yr by crazybond700
