November 6, 201015 yr would these fit fantic 125/200 trial http://cgi.ebay.co.uk/dt125-dt100-dt175-twinshock-new-rear-shocks-chrome10m08-/320609933119?pt=UK_Motorcycle_Parts&hash=item4aa5d7573f
November 6, 201015 yr They are most likely too short, you need to establish the correct length of your Fantic shocks which will be probably be around 13.5"/340mm. The bush size for the Fantic is probably 8mm, it doesn't say what these are so the bushes may need changing in order to get them on the Fantic. As to whether they are suitable for use on a Fantic depends on how seriously you use the bike. For trials use they are going to be too hard in both damping and spring rate. As they are probably about 1" too short this will lower the back of the bike and make the steering rake longer which will effectively destroy the trials geometry and handling. If you are just using it as a field bike where handling doesn't matter you could probably use them.
November 6, 201015 yr the fantic has 360mm shocks so these are almost two inches short to start with,,
