good spark
hi all can anybody tell me how to get a good earth? ive took the coil off and sanded the frame down to metal ive put coil back on its a beter spark but think it should be beter my new coil should be hear tomorrow from bultaco uk the old one is rusty and the bolts would it make diffrance with the new coil and bolts? allso would a front wheel off a purstang m8 fit my 199A :icon_rendeer:
There are lots of possible causes for a poor spark not just a poor HT coil earth.
also consider:
Poor stator coil earth
Capacitor condition
Stator to magnets clearance
Stator plate rotated away from ideal position
Points dirty/wrong gap
Poor connections in wiring
Poor earth from motor to frame
Leakage to earth via kill switch or points wiring
MK8 Pursang front wheel should fit in the front end of a M199A. May need work on axle length, axle spacer and brake stay arm.
I think you need different wheel bearings as the axle is thinner
Oh yeah thats right Ross and the Pursang backing plate would need to be sleeved down.
thanks for the addvice havant had chance yet to have a tinker
