HELP FORK SEAL CHANGE
hy just stripped my forks and fully cleaned the only thing im struggling with is the bronze bushing is there any tips on how to nock that back down as i dont have a seal driver and dont wants to buy one as ill prob never use it again ,and wich way does the seal go in ive been told both ways now and totally confused regards ste
2 1/2 inch plastic pipe use that as a driver works real well...all the best Des..
i used a old silicone tube but no good like so that bronze bushing you just have to wack it down
For the Betas I've worked on the 2 1/2 plastic PVC pipe cut to about 24" worked perfectly and cost only a few dollars. I also have 8' of extra to make seal drivers for my friends, or one for each fork leg of two bikes, or a didgeridoo.
