January 16, 201115 yr I've got my carb off and going to clean it. I'd like to know what size the carb is in case I need a bowl gasket. From what I'm seeing it looks to be a VM26. This is for an`01 Beta 250 Rev 3 Not an `02. Edited January 16, 201115 yr by DMX84
January 17, 201115 yr I've got my carb off and going to clean it. I'd like to know what size the carb is in case I need a bowl gasket. From what I'm seeing it looks to be a VM26. This is for an`01 Beta 250 Rev 3 Not an `02. Yes, that would be correct.
January 17, 201115 yr Author You won't need a gasket unless you let yur kid clean it dean. I'd really like to soak it in some carb cleaner, but since the gasket is "glued" to the main body I can't do this.
January 17, 201115 yr I'd really like to soak it in some carb cleaner, but since the gasket is "glued" to the main body I can't do this. You just need to clean out all the jets and blow out the air passages. Been talkin` to too many car mechanics again.
