hamtrux Posted January 26, 2011 Share Posted January 26, 2011 Hi, newbie here.I am seeking some advice on the problem I have with my 04 scorpa, it boiled up last time out and spat steam from breather pipe on the rad,bike starts and runs fine.so, I have tested the fan with a 12 volt battery and it spins super fast.also, I bridged the wires to the thermostat(removing it from the equation) and started the bike..this would make the fan run ye??not on my bike, it only turns at a very slow speed and I can stop it with my finger.I think its voltage or current related...it defo gets some but not near enough to cool the bike.coolant level is fine and mixed correctly.also, my headlight stopped working,not checked that at all as yet any advice of what to check next?regulator maybe? thanks for reading. Quote Link to comment Share on other sites More sharing options...
legionnair Posted January 26, 2011 Share Posted January 26, 2011 remember to check and clean all your grounds dustin Quote Link to comment Share on other sites More sharing options...
hamtrux Posted January 26, 2011 Author Share Posted January 26, 2011 remember to check and clean all your grounds dustin ok will do that tonight.gonna make a few calls and try find out more info today thanks Quote Link to comment Share on other sites More sharing options...
ham2 Posted January 26, 2011 Share Posted January 26, 2011 I'm not a Scorpa-ist so I can't recall the details. Do a search on here,I'm sure this is a common Scorpa SY problem? Quote Link to comment Share on other sites More sharing options...
godzilla Posted January 26, 2011 Share Posted January 26, 2011 Are there any cables odstructing it? Quote Link to comment Share on other sites More sharing options...
hamtrux Posted January 26, 2011 Author Share Posted January 26, 2011 Are there any cables odstructing it? Thanks folks, problem solved, some of the wiring at the headlight is abit ropey and needs tidying this some how stppoed my fan from running...av solved the problem( overheating) and i now need t remove a switch up at the headlight..... Quote Link to comment Share on other sites More sharing options...
