March 5, 201115 yr Just got my 2006 Beta 250cc Rev 3 today and noticed the exhaust silencer is worn through slightly on the inside (wheel side) where the tyre must have rubbed against it. What can I do to repair this? Or where do I get a new silencer from? I have seen things about this being a common problem and solutions being things like bending out the mounting bracket or packing it out with washers and having looked at mine it is now packed out with 3 or 4 washers, but I may try bend the bracket out a little further. Just want to know if there is a way I can correct the damage already caused.
March 5, 201115 yr Yep they do tend to catch wheel check mount bracket is ok! Take mudguard off and make sure it aint cracked! I had a couple snap on me on my old 06 rev3. You can get new bracket and silencer from john lampkins beta importers silsden! I dont think silencer is cheap though.
March 6, 201115 yr This was one of the problems I had with my Rev3,all I did was Tig weld a patch over it to let that take the wear.I just accepted that it was a bit flimsy and very close to the wheel.
March 6, 201115 yr The more washers you put on the more it pushes the bottom of silencer in to the wheel.
