April 16, 201115 yr I don't suppose anyone has a copy of 'The Road Vehicles (Display of Registration Marks) Regulations 2001' by any chance? 2. GENERAL LOCATION 2.1. The mounting for the rear registration plate of a motorcycle, motorcycle combination or tricycle must be located at the rear of the vehicle in such a manner that: 2.1.1. the plate can be positioned within the longitudinal planes passing through the outer extremities of the vehicle. 3. INCLINATION 3.1. The rear registration plate: 3.1.1. must be at right angles to the median longitudinal plane of the vehicle; 3.1.2. may be inclined from the vertical by not more 30
April 16, 201115 yr Cheers for that bulltaco, I knew there would be some technical jargon somewhere that would burst my bubble If only the authoroties could instill such precision to some of the drivers out there? So the moral of the story is that unless you have a full size plate with the correct lettering, spaces and borders mounted in a specific manner then you're liable to be nicked me old son! Just as well most local constabularies employ some common sense when there's a road trial event going on? GJ
