June 11, 201115 yr ive noticed sometimes when downshifting the gear dosent actually drop, it almost drops them seems go back in to the gear it was in, but if im hardly moving, or stood still, all gears change no problem... is this normal or does something need adjusting?
June 12, 201115 yr Around the 6:00 min mark explains the adjustment you are looking for. But it can be common if you are a sloppy shifted. http://www.youtube.com/watch?v=A80n7zq80n8&feature=related Good luck
June 12, 201115 yr Author just checked mine and theres no click, so i guess it needs adjusting! wish i knew this the 1st time i had the clutch etc out
