TY175 Yokes standard size to 35mm?
isaacely
Hi, has anyone tried boring out ty175 yokes from the standard size to take 35mm diameter forks? Are they strong enough if you take out enough metal to fit 35mm forks into them? Thanks for any advice you can give. Alan
Edited by isaacely
TY175 yokes have the fork legs angled forward relative to the steerer whereas the TY 250 ones are parallel?
I will do a fork swap to my 125TY too, got my hands to a complete front end of a TY250 from 86 I believe.
There you have distance difference from at least 4mm between higher clamp to lower clamp (lower clamp is >/+ 4mm farther away) to the steering axle.
But distance between the stanchions is wider so you need a new front wheel axle and bushings.
