August 25, 201115 yr Right well i got another bike 08 raga 250 got the stand which needs putting back on as its always handy when your having a break, just never got any bolts could some kind soul please check what size they are im guessing they will be same in most... its got the 09 frame so 09 onwards might be best. Thanking you!
August 25, 201115 yr The parts catalogue lists 2 Alen screws M8x20 and 1 Hex head bolt M6x16. Mine has a spacer fitted under the head of one of the M8 bolts so the bolt head acts as a stop for the stand (when it's up). a stack of M8 washers will do the same job if you want and be cheaper!
September 6, 201115 yr Author Havnt been on in a while thanks for that Rich , totally forgot that it lists parts in the parts cat. Cheers though yeah will try that too.
