1996 Fantic 250
mudgnome
If it has an aluminum frame I would check for cracks. Manuals are hard to find and in Italian.
hi had one back in the day good bike :thumbup: normal stuff to look for it will have a steel frame and alloy swing arm check out the foot peg brackets bit soft also brackets around exhaust strange sub frame but all in all good bikes :thumbup:
  • 2 months later...
Hi,going to look at a 96 Fantic 250 on Friday.What are the main things I should look for ??.Also where would I get a Manual for one?
I need some specs on these for servicing if I do in fact pick it up.
Thanks.
[/qu
Make sure it has a good spark, check for cracks in the frame near the steering head.
The Rubber boots between the carb and the airbox are getting tough to find.
If you pass on it I know some guys that may be interested on the NY side of the border.
Good luck, let me know how it works out.
Edited by yeogene
