September 17, 201115 yr hi guys ive desided to have my fork legs powder coated my question is when i get my forks back from the spray shop im puting new seals in. if i heat the leg up to get the seals in will it do any damage to the paint? supid question i know but i dont want to damage the paint work affter paying
September 17, 201115 yr Don't heat up the legs to put the seals in. I agree. There should be absolutley no need to heat the fork legs !
September 17, 201115 yr Author Don't heat up the legs to put the seals in. thanks for the addvice so whats the best way to put them in?
September 17, 201114 yr A little lube on the seal and a piece of PVC pipe the same size as the seal. Tap it in evenly with a hammer. You can also use the old seals to drive in the new. They're always exactly the same size
September 18, 201114 yr Author A little lube on the seal and a piece of PVC pipe the same size as the seal. Tap it in evenly with a hammer. You can also use the old seals to drive in the new. They're always exactly the same size thanks for your help cheers bondy
