fred_savage Posted September 27, 2011 Report Share Posted September 27, 2011 Does your Evo P##s fuel out of the cap overflow? Has anyone found a remedy for above? Quote Link to comment Share on other sites More sharing options...
Guest DGShannon Posted September 27, 2011 Report Share Posted September 27, 2011 Does your Evo P##s fuel out of the cap overflow? Nope. No problem. Quote Link to comment Share on other sites More sharing options...
mattholmes Posted September 27, 2011 Report Share Posted September 27, 2011 Only if I stop really quickly and the fuel swishes around and a bit comes out the breather tube but nothing major ??? Suspect this would happen with most bikes ?? Quote Link to comment Share on other sites More sharing options...
lineaway Posted September 28, 2011 Report Share Posted September 28, 2011 Put a one way valve in the over flow. Quote Link to comment Share on other sites More sharing options...
fred_savage Posted September 28, 2011 Author Report Share Posted September 28, 2011 I have had two caps now, both have allowed an unacceptable amount of fuel to spill, especially when descending. I have not been filling the tank in an effort to lessen the problem. Quote Link to comment Share on other sites More sharing options...
Guest DGShannon Posted September 29, 2011 Report Share Posted September 29, 2011 I have had two caps now, both have allowed an unacceptable amount of fuel to spill, especially when descending. I have not been filling the tank in an effort to lessen the problem. How do you have the vent hose routed? When my cap is screwed down tight, the vent hose points forward, toward the steering neck. My hose then loops up, over, and back to tuck into the rubber sleeve, with all the other cables, disappearing into the right side bodywork. Without this up and over loop in place, I could see the possibility of a problem, and even siphoning, when pointed downhill, as you describe. Quote Link to comment Share on other sites More sharing options...
