Montesa 348
jojotut
Hi anyone point the way to dateing my 348's.
I have one number stamped on the front engine of one machine but the other stamped behind the barrel? both are 51M, was there any change over the model over its lifetime to the engines or can one engines parts be used in the other.
Thanks
Thanks for that, the 348 with the engine number on the front starts 51m 129* the other one with the number at the back of the engine is 51m 160*. These mach up with the frame numbers.
Whats the difference between the standard and the Cota bikes you mention?
