October 21, 201115 yr Hi a friend of mine has an 2003 gas gas 280 that needs a fork service I have found parts diagram by searching on here but no oil quantity's ! I would be gratefully if anyone can help also he is no lightweight 6 foot 5 and 20 stone so recommendations welcome on oil welcome .
October 21, 201115 yr Hi a friend of mine has an 2003 gas gas 280 that needs a fork service I have found parts diagram by searching on here but no oil quantity's ! I would be gratefully if anyone can help also he is no lightweight 6 foot 5 and 20 stone so recommendations welcome on oil welcome . All You need here I think: http://www.youtube.com/watch?v=AP-v_c0g0mw -Jan
October 21, 201115 yr Hi a friend of mine has an 2003 gas gas 280 that needs a fork service I have found parts diagram by searching on here but no oil quantity's ! I would be gratefully if anyone can help also he is no lightweight 6 foot 5 and 20 stone so recommendations welcome on oil welcome . Jan's link will help a lot. Your friend may also want to make new preload spacers about 8 or 10mm longer (the grey PVC spacers above the spring) and use about 320cc's of Dexron ATF (about 7.5 weight) as fork oil. At 280 lbs, he should look into using heavier springs as you can only compensate so much for the added sprung weight. Jon
