Rev timing
barfy
Hi,
Does anyone have instructions on how to check the timing on a 2004 Rev 50?
I replaced the seal behind the flywheel on my sons Rev 50 last week because the engine was smoking quite a bit when cold. It didn
Sounds like other side crank seal as gone & burning gearbox oil!
Thanks for the suggestion. Long time since I had a two-stroke this old. I'll look to get one on order.
Do you know how to check if the timing is right?
