bondy Posted November 17, 2011 Share Posted November 17, 2011 hi all ive just got got a new bush kit from bultaco uk for my 199A as anybody else had one? ive put the outer bush in nice tight fit was easy enough to put in the inner bush made of alloy was allso tight these should turn freely the only other thing i can think of is they will get free when swing arm is on anybody agree? I hop so Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted November 18, 2011 Share Posted November 18, 2011 hi , you would expect it to be free is it a case of slightly reaming the inside of outer bush ,like you would a lorry kingpin Quote Link to comment Share on other sites More sharing options...
woody Posted November 18, 2011 Share Posted November 18, 2011 If they are tight they will stay tight and not free up with use. Either the outers will need reaming out or it may be possible to turn some off the inners. All depends on the the way they sit together. You need a competent machinist to look at them to decide which and to do it. Quote Link to comment Share on other sites More sharing options...
bondy Posted November 19, 2011 Author Share Posted November 19, 2011 If they are tight they will stay tight and not free up with use. Either the outers will need reaming out or it may be possible to turn some off the inners. All depends on the the way they sit together. You need a competent machinist to look at them to decide which and to do it. ok thanks for your addvice guys Quote Link to comment Share on other sites More sharing options...
