November 21, 201115 yr Hi all, I have a beta rev 3 and it seems to be running a little rough, it starts fine but on idle the revs seem to be slightly up and down. It seems a little worse when riding, especially in second gear on mid revs it gets very jerky. If anyone has come across this problem or has any ideas on a possible fix i would be very gratefull. Thanks
November 21, 201115 yr Hi all, I have a beta rev 3 and it seems to be running a little rough, it starts fine but on idle the revs seem to be slightly up and down. It seems a little worse when riding, especially in second gear on mid revs it gets very jerky. If anyone has come across this problem or has any ideas on a possible fix i would be very gratefull. Thanks try new plug what is condition of plug ,clean carb out ,could be running rich fouling plug to prevent this lift clip on needle thus lowering needle
November 23, 201114 yr Author i put a new plug in when i first brought the bike, the old plug was in fair condition and with the new one it made little or no difference. I will try your other suggestion though. thank you
