Fitting a 300 seat to a 240
fantic 300 pro
post-1232-0-77699400-1324237094.jpgI have a 300 seat waiting to go on my 240 too, just haven't got around to it yet ...
All you have to do is remove the stock seat and the side panels , set the 300 seat in place where it will hold your tank down correctly and you will see right where you have to weld some bolt tabs to the frame to line up with the 300 seat bracket bolt holes ...! Basically dead center of the rear side cover hole . If done correctly cover will still snap in place ...
Glenn B)
Edited by axulsuv
