kickstart problem
scotty300
Just installed a new kickstart quadrant on my 09 300 pro. The shaft is in place with the spring loaded. When I push the kick start down the quadrant engages with the idler gear and turns it, however on the return the quadrant and the idler gear do not dis-engage. Any suggestions?
Cheers
Cheers
Try: http://www.trialspartsusa.com/tech.html and click on the link- "GASGAS Pro Technical Bulletin", that might help.
Jon
