jsp Posted February 7, 2012 Share Posted February 7, 2012 No theres only wheel spacers which fit in the bearings and there both there, did try using a washer but it did the same, then when i removed the bolt and cam from the brake side you could see the mark that the spindle had made. which ment everything is tigtening up to the spindle but that isnt enough to tighten the wheel in the swinging arm jsp Quote Link to comment Share on other sites More sharing options...
sunlingkau Posted February 7, 2012 Share Posted February 7, 2012 let me check Quote Link to comment Share on other sites More sharing options...
borus Posted February 7, 2012 Share Posted February 7, 2012 With the new rear bearing kit the alxe length is maybe 1mm too long. Simply shave 1mm off the end of the axle or grind and you will find no issue. cheers Quote Link to comment Share on other sites More sharing options...
jsp Posted February 7, 2012 Share Posted February 7, 2012 thanks for the info everybody, i will get it sorted and keep an eye on it jsp Quote Link to comment Share on other sites More sharing options...
