February 9, 201214 yr Unfortunately that isn't the case anymore for those who pass a test in the UK for 17-19 yr olds, they are now restricted to 125's, though I see the chap if from Canada, so maybe best to pass a test over there where I assume the laws are different. DVLA website says "After passing the standard motorcycle practical test, you will be restricted for two years to riding a bike of up to 25 kW and a power/weight ratio not exceeding 0.16 kW/kg. After this you may ride any size of bike" How many kW does a 280/290/300 2T trials bike kick out? Given the weight of most modern trials bikes (70kg ish), to pass the 0.16kW/kg measure the bike can't kick out more than 11kW?
February 10, 201214 yr DVLA website says "After passing the standard motorcycle practical test, you will be restricted for two years to riding a bike of up to 25 kW and a power/weight ratio not exceeding 0.16 kW/kg. After this you may ride any size of bike" How many kW does a 280/290/300 2T trials bike kick out? Given the weight of most modern trials bikes (70kg ish), to pass the 0.16kW/kg measure the bike can't kick out more than 11kW? Good lord ..modern living ...how petty and crass can the law get...has nobody any common sense any more?
February 16, 201214 yr Good lord ..modern living ...how petty and crass can the law get...has nobody any common sense any more? NO!!
