February 28, 201214 yr Hi, I'm thinking about a modified steering angle on my TlR 200 to get a more modern Geometry,what do you think about this??
February 28, 201214 yr Makes a big difference. Need to ensure footrest position are correct and also adjust wheelbase as will be shorter after mod
February 28, 201214 yr I'll be interested to see what replies this thread gets, especially on the recommended angle(s) and how the angle is measured. From talking to other people who have changed the rake angle I pass on the advice to make sure that whatever angle you do choose that you still have clearance between front mudguard and frame downtube. If you use mudguard risers for muddy conditions then check the clearance with the risers fitted.
February 29, 201214 yr Author @Jimmyl, The footrest position has been lowerded for +-2cm,what do you think about the wheelbase?? I'm thinking to cut in the frame on the top tube for about 6mm. Thanks, Jeff
February 29, 201214 yr I left the top face of the top frame tube intact and cut a v through the lower parts of the frame and gusset. I measured distance from spindle and steering head to wall in front. Then set to same dims as my 4rt. seemed to work. Lost about 1" on wheelbase which I have added to swing arm to get back to approx 52"
March 1, 201214 yr Author So you modified your swingarm or you bought a longer one? I would measure the distance from the centre of the swingarm axle to the centre of the frontwheel axle and compare it to more modern trial bikes. After that i would compare the swingarm length to the actual bikes and modify it,if possible!
