ben3010 Posted May 4, 2012 Share Posted May 4, 2012 Hello everyone, does anybody know where I can source a new headset for my James (55K7) thanks. Quote Link to comment Share on other sites More sharing options...
totalshell Posted May 12, 2012 Share Posted May 12, 2012 if the ball races are shot rather than the balls nows the time to go taper roller, easy/ cheap and better! Quote Link to comment Share on other sites More sharing options...
brian h Posted May 14, 2012 Share Posted May 14, 2012 Hi, I restored a basket case 1955 James Commando last year and found the steering head ball races completely worn and decided that taper roller bearings were the answer, this involved turning up a upper and lower taper bearing race carrier from Mild steelf to fit in the frame headstock, then turn down the existing spindle to suit the bores of the taper bearings, its well worth the effort to modify the steering away from the ball and cones - I doubt they are available anymore. Hope this helps. Quote Link to comment Share on other sites More sharing options...
bashplate Posted May 14, 2012 Share Posted May 14, 2012 hey brian, i did a similar thing with my rocket 3 away back in the 70's only had to make 'rings' for the frame, the spindle was a dead match for vaxhaul viva wheel tapers Quote Link to comment Share on other sites More sharing options...
b40rt Posted May 14, 2012 Share Posted May 14, 2012 (edited) I doubt they are available anymore. I got some for a BSA from a cycle shop a while ago, think they were bottom bracket bearings. Edited May 14, 2012 by B40RT Quote Link to comment Share on other sites More sharing options...
ben3010 Posted June 9, 2012 Author Share Posted June 9, 2012 Hey many thanks for the replys, I was thinking taper roller but wondered if this was possible, so great I'll get the lathe powered up, cheers. Quote Link to comment Share on other sites More sharing options...
