Beta Rev 3 250 Clutch Slipping
Hi.got my beta last week.rode it twice.when I first rode it I noticed it had a little slip in 5th and 6th.now it's slipping all the way from 3rd through to 6th gear.can any one help me with any thoughts.and tell me is it hard to change the clutch plates.many thanks.
Drain the gear oil Remove clutch cover Undue the 6 bolts Remove springs and cover you should be able toget the plates out Watch for the thrust bearing and the push rod under the outer cover note the order it comes apart as reassembley is the reverse
Thanks for that.so it's pretty simple then.cheers naichuff.
It might be someone has used the wrong oil, Drain and refill with atf dextron 3, very cheap.
+1 with the ATF oil. Change it often.
So does that mean the oil makes the clutch slip and drag?
Seems like to from the myriad of clutch posts and topics.
Need to un-drag mine soon.
Thanks for the info.i did have wrong oil in.fell off of it yesterday.i think the bike is to good for me.thinking of selling it and buying cheaper air cooled model till I get used to riding again.
You will ride better on a newer bike. ...don't get an old bike to "learn" again.
