bondy Posted June 21, 2012 Share Posted June 21, 2012 hi all with out damaging the studs that hould the barrol and cylinder head down. how do i get them out? Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted June 21, 2012 Share Posted June 21, 2012 Screw two nuts on to the stud, lock them together and turn the lower one to unscrew. If both move up the thread instead of turning the stud then you may have to keep them tightened together with a pair of spanners as you turn. Quote Link to comment Share on other sites More sharing options...
stecks Posted June 21, 2012 Share Posted June 21, 2012 Hi Bondy If they try to turn with two nuts, try three. Perhaps gently tap the end of the stud to free up the thread without damaging the stud. Try some easing fluid, something like PlusGas overnight. Slide a good fitting ring spanner onto the stud before spending a bit of time ensuring the nuts are done up tight against each other, then carefully try to 'shock' the stud out using the pre-positioned ring spanner. Open ended spanners may slip. If this doesn't release the studs, you may have to try applying a small amount of heat to the casing - without melting it or setting anything on fire... Its usually the last one that is most difficult to get out, so do the last one first. Good luck. Quote Link to comment Share on other sites More sharing options...
b40rt Posted June 21, 2012 Share Posted June 21, 2012 Hot air paint stripper thingy for applying heat ! Quote Link to comment Share on other sites More sharing options...
bondy Posted June 22, 2012 Author Share Posted June 22, 2012 hi all thanks for your replys. i have now got it out with the two nuts Quote Link to comment Share on other sites More sharing options...
