wasted Posted August 8, 2012 Share Posted August 8, 2012 my gas gas jt 25 350cc keeps overheating!wen i give it sum short half throttle bursts the coolant shoots out of the over flow pipe on the radiator.can any one help as i am new 2 trials bikes and dont know wat the problem is Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted August 8, 2012 Share Posted August 8, 2012 check if fan is working ,check impella on water pump for damage (make sure it turns when engine turns ) , check correct plug fitted , check brakes not sticking , check head and replace o rings or gasket which ever it has ,also make sure radiator core is clean and sound ,check colour of plug to ensure not running lean Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted August 9, 2012 Share Posted August 9, 2012 Had the same thing back in the 90's with a 350. It was a faulty radiator pressure cap, the rubber seal had failed allowing pressure to escape hence the system overheated really easily. I changed the cap (after trying everything else) and that sorted it. Take a good look at the cap before you do anything else, it won't cost you anything to look if it's ok. Pete Quote Link to comment Share on other sites More sharing options...
motovita Posted August 9, 2012 Share Posted August 9, 2012 Overheating is a common complaint on that bike. Check all components and change to Evans coolant. Quote Link to comment Share on other sites More sharing options...
wasted Posted August 11, 2012 Author Share Posted August 11, 2012 thanks alot guys i checked the rad cap n sure enough it was split so i changed the rubber and it seems to have cured the problem but will know for sure when i ride it tomorrrow.thanks again guys Quote Link to comment Share on other sites More sharing options...
