September 12, 201214 yr After some advise on new tyres, please. My bike had the original Michelins, but they're stuffed. Should I stick with Michelin? Any other brands worth considering (Pirelli, Dunlop, IRC...) or to be avoided? The bike is not for competition, purely recreational, but I still want it to ride right. Appreciate any words of wisdom. Thanks. bird bris. au.
September 12, 201214 yr Dunlop bead wont stay on the rim below 10psi if you have standard rear rim Pirelli rear has very stiff carcass, stiff compound and smaller gaps between the knobs IRC tube or tubeless is fine Michelin tubeless is fine
September 12, 201214 yr Depends on which type of tubed rim. Some are ok some not. I may be wrong, but from what I've heard, standard TY250R rim is OK with X11 Michelin. Do you know different to this? By the way bird, which Michelin is on the rear now? Edited September 12, 201214 yr by feetupfun
September 13, 201214 yr Author Thanks guys. Ah, um, eer, the tyres went to the dump after I had to hacksaw them off they were so rock hard! So sorry, can't tell you exactly. Trial Competition rings a bell, and they had tubes, but I don't know the exact model description. Whatever was around in 1991 I guess. See you're in Gladstone, feetupfun. Who's good for tyres in Qld/ Brissy? Cheers.
September 13, 201214 yr Can get IRC front and rear pretty easy up here in Gladstone through any of the three motorbike shops and sometimes they even keep them in stock. Can get Michelin too but Michelin sometimes takes months to arrive. No idea where to go in Brisbane for trials tyres. Sometimes at big trials in SE Qld, trials bike dealers set up shop and have tyres for sale. I use Michelin fronts and IRC rears Regards David
September 14, 201214 yr Author Thanks David, I'll have to have a sniff around. Imagine the Michelins will cost more than the IRCs. There's a joint on ebay offering Pirelli here in Bris, but I think they're more trials block style for trail bikes rather than true trials tyres. Eddie. No idea about a price, but if you search ebay UK they pop up there sometimes. Also, there is no rear disk brake on the air cooled monos, though the later Z model with water cooled motor had disks front and rear. Cheers guys.
September 14, 201214 yr Michelin rears $180-$200 IRC rears $150-$180 depending on Tube or Tubeless type
September 14, 201214 yr Thanks David, I'll have to have a sniff around. Imagine the Michelins will cost more than the IRCs. There's a joint on ebay offering Pirelli here in Bris, but I think they're more trials block style for trail bikes rather than true trials tyres. Eddie. No idea about a price, but if you search ebay UK they pop up there sometimes. Also, there is no rear disk brake on the air cooled monos, though the later Z model with water cooled motor had disks front and rear. Cheers guys. lots were modified to add a rear disc brake.
September 22, 201213 yr Thanks David, I'll have to have a sniff around. Imagine the Michelins will cost more than the IRCs. There's a joint on ebay offering Pirelli here in Bris, but I think they're more trials block style for trail bikes rather than true trials tyres. Eddie. No idea about a price, but if you search ebay UK they pop up there sometimes. Also, there is no rear disk brake on the air cooled monos, though the later Z model with water cooled motor had disks front and rear. Cheers guys. If you compare the tread style and pattern between a mich and a Pirelli there really is no difference. The Pirelli MT43 is a slightly harder compound thus offering a little more wear.
September 24, 201213 yr Author One last tyre question, please: Do tubeless tyres work on the TY250R, ie, the new Michelin Trial Light? Cheers.
September 24, 201213 yr As far as I'm aware only if its a tubeless rim. Someone may correct me there.
September 24, 201213 yr As far as I'm aware only if its a tubeless rim. Someone may correct me there. yeh thats why there is two different type of tyre
September 24, 201213 yr yeh thats why there is two different type of tyre And two diff type of rim no??
