pat64 Posted October 16, 2012 Share Posted October 16, 2012 can anyone tell me where the speedo pick up is on this bike ,I've had a look but cant see anything, Quote Link to comment Share on other sites More sharing options...
goudrons Posted October 16, 2012 Share Posted October 16, 2012 number 45 here on the front axle. http://www.haventrialsport.co.uk/index.php/1999-frame-c-171_185_187 They were often removed and a spacer fitted when the speedo was removed. Quote Link to comment Share on other sites More sharing options...
pat64 Posted October 16, 2012 Author Share Posted October 16, 2012 number 45 here on the front axle. http://www.haventria...e-c-171_185_187 They were often removed and a spacer fitted when the speedo was removed. thats different from mine ,mine has the electronic speedo in the tank cover Quote Link to comment Share on other sites More sharing options...
pa. Posted October 16, 2012 Share Posted October 16, 2012 Pickup was a magnet on the rear wheel. From memory it was a Cateye speedo, or at least looked just like one. They didn't work very well as the ignition system would interfear with them, but they worked well when the engine was off. Quote Link to comment Share on other sites More sharing options...
lineaway Posted October 17, 2012 Share Posted October 17, 2012 The line went with the brake line to almost the caliper. Had a pickup on the spokes. Not worth fixing . Find a newer bike speedometer that might last a little longer. Quote Link to comment Share on other sites More sharing options...
pat64 Posted October 17, 2012 Author Share Posted October 17, 2012 thanks guys,it looks like some one has ripped it off anyway, I just wanted to keep the speedo in the tank cover ,so I'll see if I can find something more reliable that will fit the hole in the tank cover. Quote Link to comment Share on other sites More sharing options...
goudrons Posted October 17, 2012 Share Posted October 17, 2012 I need some glasses! I read (and found) 1999 Techno, not 1996, sorry. Yes, the earlier models had a pick up off the rear wheel. Quote Link to comment Share on other sites More sharing options...
