Clutch Hose Options
I snapped the clutch hose clean off at the point it goes into the reservoir/lever.
It looks as if they are £53 for a replacement (2004 Beta Rev3). Which is more than for Gas Gas & Sherco.
Has anyone found a cheaper repair/replacement ?
I snapped my clutch at the same place on my evo.
Went to a car tuning shop nearby and bought a fitting that tightens on with an olive. They are a standard sized thread and was about 2 quid. Just have to cut the old fitting off first so you lose an inch or so of length but its not a problem. Only Bad part is, its not a swivel fitting, so you have to play around a bit to get it to tighten at the right point so that your master cylinder is the right way up when you finish.
Oh and the fitting i bought had a concave end, rather than a flat one, so i had a mate machine the end flat on a lathe.
If you can get a Banjo fitting like on Sherco pre all these modern types it will be harder to snap off...have a look at Sherco's
Always get some spare olives so if you tighten wrong you can do it again.
You snapped the pipe union and not the perch itself?
