Carb Conversion
There's a kiehin carb for a xer pwk 28 can u use them on a gasser with the right jets. How much would a conversion like this cost
Aside from the cost of the carb, you would either need to buy a raga intake manifold or Jitsie adapter to convert the bike from a Dellorto 26mm to the Keihin PWK 28mm inlet. You would also need a Keihin type throttle cable.
PWK28 carbs off 80/85cc mx bikes seem to list on ebay from 70gbp/100usd upwards but who knows what throttle slides they use, jets & needles are fairly cheap & easy to buy but the slides aren't cheap-somewhere in the 60gbp range from splatshop.
Probably easier/cheaper to buy a carb & manifold kit that is already set up rather than buy the individual parts
Complete setup
http://www.splatshop.co.uk/Gas Gas-raga-reed-block-and-keihin-pwk-28-carburettor.html
Manifold/reedvalve only
http://www.splatshop.co.uk/Gas Gas-raga-reed-block-assembly-for-kehin-pwk-28.html
As you can see it works out a lot cheaper to buy the whole lot in 1 go than getting a carb & rejetting it as well as buying the manifold/reed valve
