gasgasstu Posted January 20, 2013 Share Posted January 20, 2013 Where will I find the engine #. Looked but cannot find Quote Link to comment Share on other sites More sharing options...
jimbo349 Posted January 20, 2013 Share Posted January 20, 2013 On the top of the crank cases behind the barrel Quote Link to comment Share on other sites More sharing options...
gasgasstu Posted January 20, 2013 Author Share Posted January 20, 2013 no cannot see it there. Antwhere else to look? Quote Link to comment Share on other sites More sharing options...
stillers1965 Posted January 20, 2013 Share Posted January 20, 2013 On the front motor mount right under exhaust . Quote Link to comment Share on other sites More sharing options...
gasgasstu Posted January 23, 2013 Author Share Posted January 23, 2013 will it be a mix of numbers and letter like the frame? Quote Link to comment Share on other sites More sharing options...
jimbo349 Posted January 23, 2013 Share Posted January 23, 2013 The number should be the same as the frame. The casing have other numbers that are matching numbers as the cases where graded in the factory and matched together then have the same number stamped on the two halfs of the case. These numbers are usually on the engine mounting lugs and usually are a two digit number. Quote Link to comment Share on other sites More sharing options...
gasgasstu Posted January 23, 2013 Author Share Posted January 23, 2013 There are 2 digits on each side of the casings at the rear mounting point of the engine where it is bolted to the frame/swinging arm(36 stamped on each casing). The frame number is 51m1646 Quote Link to comment Share on other sites More sharing options...
stillers1965 Posted January 23, 2013 Share Posted January 23, 2013 On the front motor mount... Quote Link to comment Share on other sites More sharing options...
gasgasstu Posted February 5, 2013 Author Share Posted February 5, 2013 OK found it and matches the frame. Thanks Quote Link to comment Share on other sites More sharing options...
